1996 accent beta swap
I have looked through the large ammount of info you have posted on the site, jst want to clear it up thats all. The car is my daily driver so I jst want the swap to be done over the weekend so im not out a car thanks again.
If you have a specific question, ask it. If it hasn't been covered before those who know will be glad to help. If it has (which is likely) they still might. Just saying "I know information is out there but could you please spoon-feed it to me" is probably not a good way to get much help.
Ok thanks for your help.
1) Do i need to change the wirring harness at all? or will current stock sohc 1.5l harrness work?
2) If i keep the stock harrness wht is the best step Piggy back 1.5l ECU or jst get Tib ECU?
3) Motor mounts and mods to thm? can i keep stock mounts with some minor mods?
I only asked becuse from wht I have read the 96 isnt as easy as 98-99 x3 with all the above questions, but from what i can gather Im gonna need a:
trans-96 Accent GL 5spd (factory accent axles)
95 scoupe turbo clutch kit
accent release bearing
tibb flywheel
tibb trans mount
1999 Tibb 2.0l
Basic swap parts ie, belts, waterpump ect
Mods:
obx underdrive pulley
header
cam gears
tibb flywheel
tibb trans mount
1999 Tibb 2.0l
Mods:
header
cam gears
