Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
1.5L tanny on a beta
Old May 28, 2008 | 01:52 PM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
Default 1.5L tanny on a beta
I was just thinking about this.
Will a 1.5l tanny work on a beta motor?
The reason I ask this is because of the flywheel. The 1.5 has a smaller flywheel than the beta or 1.6L!
What do you beta swapers think?
Old May 29, 2008 | 04:14 PM
Yes it will work. I am not sure of the clutch/flywheel combination specifics but I know it's been done. I think searching on HP will probably find the answer.
Old Sep 16, 2009 | 07:53 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
it dose work, you will have to you the beta flywheel and clutch disk, scoupe turbo pressure plate and bearing from the alpha tranny...
Old Sep 16, 2009 | 08:16 PM
it works
dont plan on it lasting very long
but yes it does work
Old Sep 29, 2009 | 05:46 PM
accent00's Avatar
Vehicle: 1998 hyundai accent
yeah it work i used a 1.8 mitsubishi mirage clutch and the release bearing from the 1.5 accent
Old Sep 29, 2009 | 10:54 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
The problem with using the 1.5L trans on the beta is the fact that you have to notch out a section on the beta block to get the slave cylinder for the clutch to fit.
Old Sep 29, 2009 | 11:14 PM
Juanra's Avatar
I did not have to do that!!!
Old Oct 1, 2009 | 09:32 AM
HotBlue02's Avatar
Maybe theres been small changes, i had a 1.5L manual trans from a 02 Accent and a beta 2 motor from an 02 elantra, that was the issue with me so i just used the 02 Elantra manual trans instead.
Old Oct 1, 2009 | 04:15 PM
Juanra's Avatar
that can be it, i use 97-99 X3 tranny...
