Hyundai Genesis Forum The Hyundai Genesis Forum. An area for the all new generation RWD Hyundai sports coupe and sedan.
What size tires?
Old Nov 19, 2013 | 05:35 PM
wild-N-out's Avatar
Default What size tires?
Want to buy a set of XXR's and these are the specs:
Front: 18X9.0 with +25 offset, 2.5" lip
Rear: 18x10.5 with +20 offset, 4.0" lip
Bolt Pattern: 5 Lug, 5x114.3 & 5x120
I have stock size tires and wheels on now (225/45/18, 245/45/18). What size would be best for the new sizes? I would like to try and keep it so my speedo/mph isnt changed too much. I'm lowered on H&R Sport Springs.
Old Nov 19, 2013 | 06:22 PM
I would personally roll with 245/35 and 275/35. A wheel that aggressive will have poke without going lower and dialing in some camber. If you go lower, it may be more difficult to fit 275 on the rear
Old Nov 19, 2013 | 07:09 PM
18x10.5 with a +20 is super aggressive. You wont have to really put any negative camber on since you're only dropped like 1.5" but the rear wheels will stick out from the fender a bit. So if you dont like it sticking out past the fender, add some camber to it.
