Hyundai Genesis Forum The Hyundai Genesis Forum. An area for the all new generation RWD Hyundai sports coupe and sedan.
Safe jack point
Old Dec 5, 2011 | 02:05 PM
Xavier's Avatar
Vehicle: 2010 Genesis Coupe 3.8
Default Safe jack point
Where is the safest and best spot to put a jack to lift up the front and rear of the Genesis?
Old Dec 5, 2011 | 02:10 PM
There are notches on the side rails of the car. Behind the front tires and in front of the rear tires. Place the jack between the notches.
Old Dec 5, 2011 | 02:16 PM
JonC's Avatar
Vehicle: 2011 Gen Coupe
I asked and someone said to use the crossbeam at the front and by the differential in the back... take that as a suggestion or a place to start only! Don't want the jack to go through something important
Old Dec 5, 2011 | 07:49 PM
I use the uhm... bar behind the rear differential (stock photo below - the bar with the holes in it) for the rear.
The front -- what crossbeam? Not sure there is one on 2.0?
Old Dec 5, 2011 | 09:52 PM
300D50's Avatar
ALWAYS remember to touch-up the paint every time if you use the factory jack points. I suggest super-tough undercoating.
If you don't, you WILL have rust issues if they salt the roads.
Old Dec 5, 2011 | 10:39 PM
When using the "place between the dimples" jacking points, please remember to raise and lower the car gently to avoid crushing the rib. On RDs this sis a serious potential problem; I've no idea if they thickened it since then.
Old Dec 20, 2011 | 09:10 AM
davidp's Avatar
this is how i always been doing... i was afraid to crush the ribs ..
Old Dec 20, 2011 | 12:53 PM
Red Raspberry's Avatar
That's a good idea. I had some frame stiffeners on my last car welded in that attached the front and rear along those rails. Made an excellent jack point(s)
