People with tablet installs....question
Maybe someone can chime in, but when you have GPS/maps running on your tablet....are you still able to play music as well? Or is it basically the GPS voice OR music...not both?
The tablet will function through your AUX input, so you can either listen to the radio/XM through normal method OR listen to music through your tablet, in which case the GPS (depending on the app) will give directions on top of the music that's playing (it doesn't pause, the tablet continues playing music while GPS speaks). Imagine plugging in your phone using the AUX port and listening to music while running your GPS, it works the exact same way.
by the way, I was able to find a free version of Sygic (normally ~$30?) and it's AWESOME. Shows me red light cameras and is always exact with where the speed limit signs are and everything. It tells me my speed via GPS and displays the current speed limit, and I have it beep if I go 10+ mph over the speed limit
NavFree is what most people use, because, well... it's free.
Vehicle: 14 EGT 2.0
Damn it now I really want to install a tablet... thanks guys... thanks. Maybe if I calm down a bit and can tap into my rear tire fund.. hmmm
