Hyundai Genesis Forum The Hyundai Genesis Forum. An area for the all new generation RWD Hyundai sports coupe and sedan.
Oil catch can
Old Jan 6, 2012 | 01:56 PM
bathhurst_genesis's Avatar
Vehicle: 2011 Genesis 2.0
Default Oil catch can
What kind of catch can do you guys have in your car? Thinking about putting one in and getting a cheapo can off ebay.
Old Jan 6, 2012 | 02:03 PM
Home Depot Husky special. $12
Old Jan 6, 2012 | 02:25 PM
350 horsepower genesis's Avatar
Vehicle: 2011 Genesis 3.8
Be careful with some of the cheap ebay cans. I have heard horror stories of them not working very well.
Old Jan 6, 2012 | 08:02 PM
GenFlyer's Avatar
Vehicle: 2010 Genesis Coupe
I just threw one on mine (turbo side) so that oil from the crank case doesn't get vented into the intake anymore. When I changed out my stock intake for the aftermarket one it was gross what was inside it....therefore also inside your intercooler and turbo as well. Next up will be the one for off of the PCV. From what Ive read, its even more drastic on that side from all the blowby. So truly, you'll need two. Mine are red anodized cans off of ebay. Feel pretty solid. Im happy with them. And they come with two sized nipples which are interchangeable. This helps simplify because on the intake side the PCV valve and vent going into the crank case are two different sized hoses. This can eliminates the need for an inline reducer.
http://www.ebay.com/itm/250415328896...84.m1439.l2649
Old Jan 6, 2012 | 08:42 PM
Here's a great DIY for installing a catch can for BOTH sides (PCV and turbo side) using one can.
http://www.youtube.com/watch?v=k7jR_GwSFEI
Old Jan 8, 2012 | 12:41 PM
Red Raspberry's Avatar
I use two of the $20 ebay cans, one on each side. They have held up well for the last two years. On the bottom I've screwed in a brass hose nipple then lead a hose down to the subframe. Here is where I drain them every oil change.
Old Jan 8, 2012 | 05:04 PM
2.0T Mirabeau's Avatar
Vehicle: 2010 Hyundai Genesis 2.0T
I got a good deal on the AGP catch can and breather from a member it works great. They are high priced new though but get the job done very well!
Old Jan 8, 2012 | 05:49 PM
JimmyA7X's Avatar
Vehicle: 2011 Hyundai Genesis Coupe 2.0T
Thanks for the ebay link, there are so many out there so its helpful when members can be specific.
Looks pretty good, is it easy to drain? Working well so far?
Old Jan 8, 2012 | 05:55 PM
GenFlyer's Avatar
Havent needed to drain it yet but looks to be very easy. Brass knob on the bottom side that unscrews whenever you're ready to drain. So far so good. Looks great too. Very solid piece. Not flimsy at all.
Old Jan 11, 2012 | 11:45 PM
MiniMonster's Avatar
Mishimoto makes a carbon fiber one that is pretty awesome
