Lambo doors
Vehicle: 2011 Genesis 2.0 R Spec
Lambo doors
Hey guys…new member here. Thinking about buying a set of lambo doors from Vertical Doors Inc. Does anybody here have them and were you able to install them with a friend in a garage or do you have to have them professionally installed by a shop that specializes in them? Thanks.
it really depends on your level of experience and ability to think critically. You can install them yourself, but if you have to ask, maybe you should get someone to help you.
Several members have vertical doors. Wes @ G&M Performance (forum vendor) has them on his Genesis.
Got a set from Chris at Flyryde. Did it myself in 6 hours and a little bit of tweaking later on. Can be done on your own but, paint mixers are a good investment. No real issues with them other then how they open in cold weather.
It can be done on your own, however, you must be able to lift your doors with one hand and tighten bolts with the other.(hence the 6 hours)
