Heat Soaked IC
Vehicle: 2010 Genesis Turbo
Does anyone else feel like the factory intercooler gets heat soaked really easy especially when its super hot and muggy outside? Might have to look into a new one but I have no plans to upgrade the turbo any time soon. Would a different IC make a really big difference when it's extremely hot outside?
There are quite few things you can do. The factory IC is POS. About any other one would be an improvement.
You can also get eh intake manifold ported and heat coated from GrimmSpeed.
The upper radiator hose has a metal fitting that connects the two hoses and bolts to the intake. You can get a silicone one piece hose from Forge, there are others too but make sure it is one hose for the upper radiator not two.
You can open the drivers side fog light bezel for more air to the intake manifold area. Take the front and rear hood seals off too.
One thing to check out is the IAT response on your engine. On the Genesis Coupe it is so slow that there is relatively little change as you go through the gears at WOT. I don't know if this is by design or what. If you search for fast acting IAT you will see this i not limited to Hyundai and that there are solutions.
Currently I use an IAT that is from a Triumph 955.
I have a thread about this over at GenCoupe.com.
http://www.gencoupe.com/engine/11036...cting-iat.html
