Hyundai Genesis Forum The Hyundai Genesis Forum. An area for the all new generation RWD Hyundai sports coupe and sedan.
Brembo Brake Retrofit
Old Sep 13, 2012 | 02:31 PM
hawaiian genesis's Avatar
Vehicle: 2011 Genesis 2.0
Default Brembo Brake Retrofit
Is it possible and how expensive would it be to retrofit the Brembo brakes onto a Genesis Coupe without that option? I searched but could not find anything. Any idea on cost? Thanks.
Old Sep 13, 2012 | 08:14 PM
Cost depends heavily on the supplier. For a relatively new car retail will be expensive. From a wrecked junker, not so much.
Old Sep 14, 2012 | 07:19 AM
Tibbi's Avatar
Look at the web tools the only difference I can see is the caliper. Unless the rotor is also a different diameter.
It seems both bolt up the same and require the same hardware, like stocker said, if you can find a wrecked GC to scavenge them from that'll be a lot less $$.
Old Sep 17, 2012 | 05:39 PM
Red Raspberry's Avatar
The caliper and rotors need changed and in the back you need to cut off the lip of the rotor shield. Generally you can get a used set of calipers for about a grand.
