Agency Power Clutch Lines
Vehicle: 2012 Genesis 2.0 R Spec
Are these needed if you get a better clutch and flywheel installed, or can you still use the stock lines?
http://www.ebay.com/itm/Agency-Power...#ht_772wt_1185
[ebay]221066225657[/ebay]
Agency Power clutch lines are made to work for your car and include necessary hardware for a easy fitment.
Steel braided line gives your clutch pedal a much firmer feel allowing you for better control in drag racing and shifting. The lines are red with CNC machined gold ends. Great upgrade for better drivability.
They only affect the feel. The hydraulics will keep up with the mechanics in the clutch system, but a line that does not flex/swell under pressure will feel better to someone who likes feedback on what their car is doing.
