What to replace when pulling a cylinder head?
Old Sep 14, 2011 | 02:21 PM
ElantraRage's Avatar
Default What to replace when pulling a cylinder head?
Is there anything that needs to be replaced when pulling a cylinder head? I dont mean just because you have it off (i just replaced all the gaskets and seals not to long ago) I'm talking about something that if I dont replace it, something will mess up (btw I am replacing the head bolts with arp studs).
Old Sep 14, 2011 | 04:20 PM
zero_gravity's Avatar
Vehicle: 2004 Hyundai Accent
just the bolts and head gasket...everything else is optional
Old Sep 14, 2011 | 05:55 PM
bigfishmoney's Avatar
just head gasket and intake and exhaust valve oil seals.. assuming thats why ur replacing it anyways
i would reuse head bolts.. dip in oil. and torque to ft lbs and -40°, +40° x2 to each bolt. unless its a turbo application, in that case it is mandated.
Old Sep 14, 2011 | 10:36 PM
This.
bigfishmoney, the seals were described as recently replaced in the OP. Plus your 'specifications' are gibberish.
My reading of the question is: "I am replacing my head bolts with ARP studs, do I need to change anything else?" and zero_gravity got it right. If you weren't replacing the bolts, but just felt like having a peek inside the engine for some reason, all you would need is a head gasket . . . Hyundai specifies the head bolts for unlimited reuse.
