problems with my lights
Old Jun 23, 2014 | 02:43 AM
countryguy24's Avatar
Vehicle: Elantra XD
Default problems with my lights
I have a question for all of you, I have a 02 elantra and at times with headlights on when I use my turn signal my interior lights and tail lights flash. Here recently they stay off until I shut my lights off then turn them on again and then they all work. My hids stay on when all this happens, could it be my turn signal/ headlight switch on the column causing it? I want sure if anyone else has had this problem and it's really annoying especially when you have a cop behind you when it happens. Any suggestions would be much appreciated, thanks in advance.
Old Jun 23, 2014 | 03:27 AM
wheel_of_steel's Avatar
You have a bad earth on your turn signal circuit
So the power is flowing back through whatever it can to find an earth
Also I hope you don't have HIDs in XD halogen housings
Old Jun 23, 2014 | 12:11 PM
bdiggy's Avatar
Yeah. Check all your grounding points in the HID kit, and the ground in your relay if you're running one. If you have a loose connection somewhere, it's going to feed on the rest of your running electrical too.
Old Jun 24, 2014 | 04:04 AM
Vehicle: Elantra XD
I do have hids in the factory xd housing, what is the problem with that. I also do have the relay kit for them, but I have had them in there for 3 or 4 years now with no problems before.
Old Jun 24, 2014 | 06:37 AM
what's the problem with that
http://bit.ly/V8UNYU
Old Jun 24, 2014 | 07:22 PM
Vehicle: Elantra XD
I never knew that, I guess I didn't research enough when I originally got them. But back to the lights going out itis very intermittent, it could do it for several days or not even have any problems for a month.
Old Jun 25, 2014 | 10:03 PM
As someone who has done electronics troubleshooting for a living, intermittent faults are the worst. See if you can make it happen consistently. Pay attention to weather and road conditions. Try bumpy roads, try a garden hose to simulate rain, try hard turns. If it isn't broke you can't fix it and "not happening right now" means "isn't broke!"
