jdmeaux1952 |
04-12-2013 08:14 PM |
I know this is an older posting, but here's my two cents worth. When I installed my components in the front, I mounted the crossovers inside the doors, inside a plastic bag wrapped with silver "a/c" tape (the kind that impossible to come loose) so no water could easily get to it. The bag was taped to the inside of the door frame as close forward in the door as possible out of any area where water would usually travel. One year later, they still perform with no problems. Oh, before I forget. The way I have them taped down, I also punctured a small hole in the lowest point to release any moisture that may build up inside. The wiring comes into it at about the "7 o'clock position" with the hole at the "6 o'clock position".
