0-60?
Cheating.....lol Says who? The guy that lost?
Your Elantra will never gain a lot of power without spending some money. People put thousands into their Betas to only gain a second.
The manual swap will get you a good improvement though.
ill tell you from personal experience man
i spent 2 grand on na mods
(custom exhaust, header, injen intake , crank pulley, 1.8 cam, fidanza flywheel, spec/spec/act/act clutches (yes ive blown 4 transmissions before) etc.)
i dropped 1 second in the quarter mile
2 grand to drop 1 second
As far as keeping the engine bay a little cooler, you can remove the rubber weatherstrip piece at the rear of the engine bay. This will allow for engine heat to escape through the back a bit. The drawback to this is that you may need to use the defroster a bit more on cooler days, but it does help. I remove mine every summer and it's worked pretty well. No gains, but deff a cooler engine.
There are no other mods under $100 that will help you in any way as far as gains are concerned.
