X3 Accent 2.4L Engine with 4WD
Old Dec 10, 2011 | 01:59 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Default X3 Accent 2.4L Engine with 4WD
Found this at HP forums last week, thought I would drop the link.
http://www.hyundaiperformance.com/fo...d-finised.html
For those that wont go over here is a copy and paste of the post without pics but a link to cardomain.
Hello guys,
i just want to inform you that the new modification to my car has been finished
The car now has a turbocharged 2,4L hyundai 'Serius 2' engine with 4WD.I believe it will reach 500hp with a good tune.
I posted some new pictures in cardomain with the new engine and the rear differential .The dyno sheet is from the old 2.0 engine so when i dyno the new engine i will post it
http://www.cardomain.com/ride/756094...hyundai-accent
Old Dec 10, 2011 | 10:35 PM
That is seriously badass!
Old Dec 10, 2011 | 11:24 PM
HotBlue02's Avatar
Theres a nice under carriage shot on hp that I didnt see on his cardomain
Old Dec 11, 2011 | 03:37 AM
wheel_of_steel's Avatar
Whoa, what? I remember seeing this car with a beta II CVVT. No doubts about it, it was putting down 373 fwhp! Pretty sure it was only 2wd back then though. I can't find any pics though.
Seriously cool project.
Old Dec 12, 2011 | 10:33 AM
racecar13's Avatar
Vehicle: 2002 hyundai accent
would that be a 4wd santa fe swap? either way im drooling. country boys like 4wd.
Old Dec 12, 2011 | 11:39 AM
300D50's Avatar
Holy crow...
Now, can it be done on a Tib?
I'd bet finding the 5-speed Santa Fe would be about the hardest part besides slapping in the rear suspension and diff...
Old Dec 19, 2011 | 08:11 AM
racecar13's Avatar
been reading up on this. the tuscon used a beta engine and shared platform with the elantra not the santa fe. the tucson 4wd system is not very effective. its 99%fwd but xfrs power to the rear wheels when it is needed. u can lock it into 4wd but the rears only work under 25mph. maybe good for off the line launch but after adding all the xtra weight and all the work that would go into the conversion it should be full time awd.
-still researching the santa fe, i believe it is awd but uses the delta v6.
-also the theta is available in awd in the world engine alliance (evo, jeep, etc). not sure if the theta is small enough to fit in an accent engine bay or not.
Old Dec 19, 2011 | 12:00 PM
The Theta is a fairly small engine. If anything smaller than a Beta. You could get the Santa Fe with the 2.4l Sirius also.
