What does it mean to have a built motor?
Old Mar 10, 2011 | 01:29 PM
donnie's Avatar
Vehicle: 2006 Accent
Default What does it mean to have a built motor?
Forgive my newbiness but I hear the terms "built motor" alot and was wondering what defines a motor being "built?" Is it blueprinted and balanced with a turbo or supercharger, or is it something else to give the meaning of being built?
Old Mar 10, 2011 | 01:46 PM
I think that people's individual definition varies wildly, but generally if you've had to replace internal components with better ones, and/or do significant internal machining/balancing then you have at least a somewhat built engine.
Old Mar 10, 2011 | 02:20 PM
Regit's Avatar
Vehicle: 2000 tib
...also,stock motors are also blue printed and balanced,surperchargers and turbos have nothing to do with a "built" motor, they are forced induction mods added onto a stock or a "built "motor.In a nutshell "built" means a complete teardown and rebuild of a stock motor using high performance replacement parts and/or modified stock parts(ie pistons,cams,rods,etc) and/or honing,polishing,machining,shaving etc stock /performance engine parts to achieve maximum performance......so,rebuilding your engine ,replacing with stock only internals ,lowering your compression via decompression plate,adding a turbo and nos does not make it "built".
