UDP/Crank Pulley?
Old Nov 10, 2009 | 05:17 PM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
Default UDP/Crank Pulley?
Anyone know if anybody makes lightened crank pullies or UDP's for the sohc x3?
if not.. then does anyone know if any UDP's/crank pullies from any other hyundai swap on?
Old Nov 10, 2009 | 06:11 PM
Grab some measurments and Ill try to match up against a Beta crank pulley
Old Nov 10, 2009 | 06:23 PM
<div class='quotetop'>QUOTE (Ericy321 @ Nov 10 2009, 08:11 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Grab some measurments and Ill try to match up against a Beta crank pulley</div>
no prob. i'll goto the scrappers this weekend and pull off an x3 crank pulley.
I'll take detailed photos and measure everything up with a digital vernier.
il also take measurements on the actual crank and how much it sticks out including dimensions for clearance around the x3 crank, and measurements if the crank takes a keyway or not.
Old Nov 12, 2009 | 12:00 PM
Perfect. Ill check it against the Beta one I have here then
Old Nov 13, 2009 | 02:14 AM
342Four's Avatar
Vehicle: '97 X3
take a keyway
beta ones dont fit
beta hole is too big for x3
x3 sohc and dohc crank are the same
Old Nov 13, 2009 | 10:37 AM
LOL in that case.. does anyone make a UDP/crank pulley for the x3 dohc? LOLOL
