Rheostat replacement
Old Aug 6, 2009 | 07:02 PM
killersheep's Avatar
Vehicle: 2001 Hyundai Accent GS
Default Rheostat replacement
Hi there, I'm pretty new to this forum. I am having a pretty common problem with my 2001 Accent, a problem with the dash lights that are attached to the rheostat. I've seen this solution been posted pretty often, but I'm not sure about how to actually remove it (without causing any unnecessary damage of course). If someone can give me a quick rundown it would be greatly appreciated. This leads me to a follow up question, I haven't seen a chilton or haynes available for my Accent..............are there any online alternatives.
Old Aug 6, 2009 | 07:59 PM
03AccentVA's Avatar
Vehicle: 2003 Hyundai Accent
<div class='quotetop'>QUOTE(killersheep @ Aug 6 2009, 09:02 PM) </div><div class='quotemain'>Hi there, I'm pretty new to this forum. I am having a pretty common problem with my 2001 Accent, a problem with the dash lights that are attached to the rheostat. I've seen this solution been posted pretty often, but I'm not sure about how to actually remove it (without causing any unnecessary damage of course). If someone can give me a quick rundown it would be greatly appreciated. This leads me to a follow up question, I haven't seen a chilton or haynes available for my Accent..............are there any online alternatives.</div>
HMAService.com > chilton or haynes
Old Aug 6, 2009 | 08:05 PM
Not sure how to remove it specifically, but if you pull the panel it should be fairly easy from the back.
Old Aug 6, 2009 | 08:26 PM
<div class='quotetop'>QUOTE(03AccentVA @ Aug 6 2009, 06:59 PM) </div><div class='quotemain'>HMAService.com > chilton or haynes</div>
Thanks shows how really green I am with this stuff, great link muchas gracias.
Old Aug 7, 2009 | 03:05 PM
03AccentVA's Avatar
<div class='quotetop'>QUOTE(killersheep @ Aug 6 2009, 10:26 PM) </div><div class='quotemain'>Thanks shows how really green I am with this stuff, great link muchas gracias.</div>
Everyone starts somewhere. That website has got to be one of the best ideas ever (IMO). I've learned quite a bit from it.
Mine popped out with a pocket knife, went back in fine, but it's an 03, so yours may be different.
