Pulsating in brake pedal
About a month ago I changed my front brakes on my 04 Accent 1.6L. At the time I had a sticking slider pin on both calipers, to which was fixed. The car since was driving fine with no problems till last week. I got a grinding noise from my rear brakes, they had to be replaced. So today I replaced them. I had the adjuster pin adjusted all the way in and at the time loosen my ebrake cable to make it easier to remove. Put everything back together pumped the brake brake to reajust the brakes and adjusted the ebrake cable again to 8 clicks. Thing is that now I got a pulsating in the brakes, less I am going under 15 kms. What could be causing this??????? Lastly, the ebrake locks the right wheel more then the left, This mean there is something wrong with the cable??? There is no signs that the brakes are grabbing more on one side then the other. No pulling of the back end. Just the pulsating. They are new spring set, new shoes and new drums.
Thanks for any help. All I touched was the back brakes so assuming the problem is with them, not the front. |
The cable sounds like it might be sticking. Check all pivot points and lube. The rear brakes can be adjusted by putting the car in reverse and driving slowly while pushing the brake pedal in and out 3 or 4 times.
Originally Posted by pas1216
(Post 666662)
Ok but what would cause the pulsating? Out of round drum, brake cylinder? Was told to always adjust the ebrake first. That be right? |
The pulsating could be caused by the e-brake sticking. Not too sure what order they should be adjusted but I don't think it matters. It could also be a out of round drum?????? I double check to make sure nothing is sticking.
