Plenum Spacer
What are the pros and cons for installing a plenum spacer?
pro- you get to work on your car
con- you just spent $130 for nothing don't waste your money. edit- here's another thread talking about them, next time try the :search: function. https://www.hyundaiaftermarket.org/f...-body-spacers/ |
http://sharkracing.com/acecart/bin/p...cer_2_1__3.jpg
What do you guys think of this one from shark racing? |
Buy some aluminum plate, 2 gaskets, a harbor freight transfer punch set, and a good drill index.
Then you get usefull tools and skills, as well as the spacer you want. ;) |
Excellent Idea sir.
It's also an easy way to adapt another tbody onto a Beta intake manifold, just add in a set of countersinks and use countersunk allen heads instead of studs to hold the adapter on...
There is no reason to buy a spacer for your throttle body. At least that's what that looks like. I bought an IM spacer a couple years back. That did it for me. I used to take my cr out for a quick drive come back and the manifold was really warm to touch. Almost hot. With that spacer installed it was cooler and car drove smoother. Not much of a power gain, never dynoed it, but car felt better after long drives. There was a guy custom making them and selling them for cheep $20-$30. Try looking it up.
