intake manifold size?
Old Mar 18, 2003 | 06:14 AM
PrOjEcT BLuE 02's Avatar
Default intake manifold size?
ive heard its already bigger than the throttle body so what is the stock size of an intake manifold on a '02 1.6 accent. I want match my throttle body to it.
aslo what size butterfly do i need after i bore it to whatever you guys tell me>
Drew
Old Mar 19, 2003 | 02:44 PM
If I remember right, your stock TB is 42mm, and the stock IM is 44mm.
You are somewhat limited to what size you can bore your TB to. The idle air bypass passage limits the max size of the bore, unless you go with an aftermarket made throttlebody.
Old Mar 19, 2003 | 09:34 PM
Frostbyte's Avatar
He's got the 1.6 dohc alpha, I don't know what the tb size is, but the 1.5 dohc is 48mm, so I'm guessing the 1.6 is nearer to 48mm.
[ March 20, 2003, 04:11 PM: Message edited by: Random ]
