Got my last 2 rims
Old Sep 2, 2010 | 04:46 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Default Got my last 2 rims
So I had picked up 2 rims some time ago, the 5 star rims from an 07 Accent and painted them semi gloss black. I finally got the other 2 so I need to get to sanding and painting on them. I also had a bit of a dillema as my rear hubs were the 4x114 bolt pattern do to the rear disc brake swap from a Tiburon. I put the old hubs back on and drilled the rotors out to a 4x100 pattern. Everything fit well and no clearance issues in the rear with the 2 inch drop and a slightly oversized tire. Should have had 205/45R16 but im rollin 205/50R16 that is a slight problem with the front as it grabs the passenger fender a bit so ima have to roll the fender lips up front before the new rim/tires go on. Should be getting new tires all the way around in October and also touch up the first to rims were I scratched them gettin the tires on with an inferior tire changer... got a couple really good ones in stock now with helper arms for those dam low pro tires, somethin the other machine was lacking or I wouldnt have scratched them in the first place.
Old Sep 2, 2010 | 07:50 PM
AT05GT's Avatar
Vehicle: No Car Currently
Old Sep 2, 2010 | 08:03 PM
