First Modifications
Old May 27, 2002 | 04:06 PM
QS's Avatar
QS
Veniston(sp) wink
You totally lost me.
Are you talking basied on the Accents? I see where the sensors are located...In the plastic housing on the bent 45°. BUT how are you suppose to leave it in the case an attach it to your custom intake? Please show pics..
When I did it, I gained power, pick up at the high end, an throttle responce. Im not running lean or anything. An this is just takin out the stock filter an puttin on the custom civic intake.
Old May 28, 2002 | 12:45 AM
Veniston's Avatar
Hm, you've got a 2002 Accent? They may use MAP sensors like the new Elantras, I'm not sure. In that case you'd only have the one--and the civic intakes would work fine because they are MAP based cars too.
I can't fool with pics right now, I'm at work wink
Old May 28, 2002 | 03:12 PM
DynastyAccent's Avatar
If you have one sensor, can't you just attatch it in the socket meant for a sensor on the civc intake? Or, doesn't it fit?
