Electrical problems 2005 Hyundai Accent GT
Old Jul 1, 2009 | 11:37 PM
jordansland's Avatar
Vehicle: 2005 hyundai accent gt
Angry Electrical problems 2005 Hyundai Accent GT
My headlamps, power mirrors & passenger window don't work. The high beams work for my lights but the low beams don't. I replaced both bulbs checked my fuse and inside car under dash replaced the headlamp relay power window relay. I can use some help with this one. Any ideas would be appreciated. Thanks
Old Jul 1, 2009 | 11:52 PM
You check the fuses under the dash and under the hood?
Old Jul 2, 2009 | 11:45 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Does the Accent have a body control module? My moms 97 Firebird had an issue were the power windows, radio and one other thing (I cant remeber right now) would not function, the problem was with that module.
Old Jul 3, 2009 | 08:17 PM
Cujo's Avatar
<div class='quotetop'>QUOTE(HotBlue02 @ Jul 3 2009, 01:45 AM) </div><div class='quotemain'>Does the Accent have a body control module? My moms 97 Firebird had an issue were the power windows, radio and one other thing (I cant remeber right now) would not function, the problem was with that module.</div>
i dont think it does...... well i dont remember mine having one...
Old Jul 3, 2009 | 08:24 PM
<div class='quotetop'>QUOTE(187sks @ Jul 2 2009, 01:52 AM) </div><div class='quotemain'>You check the fuses under the dash and under the hood?</div>
I did swap them with fuses of the same values from other systems and it didn't make a difference.
Old Jul 3, 2009 | 08:26 PM
What is a body control module, what does it look like? I will look and see if I can find one. Thanks.
Old Jul 4, 2009 | 04:01 PM
HotBlue02's Avatar
After looking at a wiring schematic for your car you do not have a body control module from what I can see. You do however have one thing in common on all of those items acting up and that is ground wire number 4 located near the passenger compartment fuse/relay box. There is a pic on hmaservice.com but I can't copy the pic as it will not let me. It looks like a bolt that holds the ground wire and a relay up against the body.
