Dynamat wont stick
Old Jul 25, 2011 | 01:26 PM
flamewoo's Avatar
Vehicle: 2007 Accent
Default Dynamat wont stick
I tried installing my dynomat kit this weekend and it wouldnt stick to the metal panels because they were too hot. I was doing it outside. has anybody ever heard of this problem? I know if its too cold it wont stick either.
Old Jul 25, 2011 | 06:51 PM
Might also not stick if not properly cleaned. Wait until night time?
Old Jul 25, 2011 | 08:18 PM
songee623's Avatar
Vehicle: 2005/hyundia/elantra
yeah if not cleaned right then it wont stick. cant say ive heard of heat being a reason because ive seen heat guns used so you can get a better fit on shapes and curves. now humidty that might be causing it no to stick.
Old Jul 26, 2011 | 04:38 PM
bdiggy's Avatar
Clean and dry the mounting surface really well. I did my trunk in 90+ weather and it stuck just fine.
Old Jul 30, 2011 | 03:15 PM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
heat is not an issue. clean it right, not just soap and water, nor would i use a degreaser or any thing out of a can. You need mineral spirts you can find it at walmart. clean the area with that and it will stick like no other.
Old Aug 3, 2011 | 11:27 PM
corkyaccent's Avatar
Vehicle: 2003/Hyundai/Accent 1.6L
I just sprayed windex on mine.
