Can you swap an 01 ECU into an 03 or will it not work?
Old Oct 12, 2010 | 01:21 PM
Joey's Avatar
Vehicle: 2003 Accent
Default Can you swap an 01 ECU into an 03 or will it not work?
Will the 01 alpha ecu's work on an 03 engine? Need to know because of a little project Im working on for next year. smile.gif
Old Oct 12, 2010 | 08:02 PM
Are you asking if it's a direct plug-and-play? I don't know the answer to your question but this makes a big difference.
Old Oct 12, 2010 | 11:36 PM
krazytib's Avatar
Goto hmaservice.com and compare the ecu's wiring diagram to see if the pins match up.
Old Oct 17, 2010 | 11:39 PM
Ryanator's Avatar
Vehicle: 2003 Hyundai Accent 22PSI Boost
yes they work. We have a 1.5L G4EC running a G4ED 1.6L with a 3mm deco plate.
Cheers Ryan
