BETA X3 Help needed
Old Apr 10, 2010 | 12:47 PM
Default BETA X3 Help needed
Ok guys, I need to get the car running so its not just sitting around anymore. Here is the setup:
Beta Engine
Alpha Trans
Beta ECU and wiring harness
The issue I am getting is I have everything plugged in and I am not getting spark or fuel injector pulse. Im looking for anyone that has theirs set up this way that can point me in the right direction. As far as I know I shouldnt need to hook anything up inside the vehicle besides the ECU itself. I can give the fuel pump power another way. Let me know guys. Thanks!
Old Apr 10, 2010 | 01:07 PM
BayTib13's Avatar
I'm having this same problem, except i went from a beta I to a beta II, and now my engine will turn over, but I'm not getting any fuel feed, or spark impulse, the connector to it is registering that it's receiving 12V in the on position, but it stops at the coil pack. I was told to check the camshaft sensor and the crank sensor.
Old Apr 10, 2010 | 01:12 PM
did you reuse the beta 1 sensors?
beta 2 sensors are different
Old Apr 10, 2010 | 01:18 PM
BayTib13's Avatar
I dont wanna jack his topic, so here's the link to mine.
My forum
and yes, we switched all sensors over
Old Apr 10, 2010 | 01:33 PM
Mine is all Beta 1. But it seems like they are similar issues. I am going to swap out the ckp tomorrow for a new one and see where that leads me.
Old Apr 11, 2010 | 04:15 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
the fist thing you have to check is if the CEL is on.
If not I would check the crank sensor and continue checking sensor from there!
Old Apr 11, 2010 | 06:22 PM
BayTib13's Avatar
Just went over and checked all my sensors today, turns out when we electrical taped my crank sensor, it came loose inside the tape, so it wasnt getting the connection. plugged it in, sure enough it fired up.
Old Apr 13, 2010 | 06:40 PM
Havent swapped mine out yet. Hoping to do it in the next couple days. I think that should take care of my problem but we will see.
