Accent grind into 2nd
Old Feb 5, 2010 | 07:50 AM
Stormtrooper's Avatar
Vehicle: 2003 Accent
Default Accent grind into 2nd
Hi,
My accent has a problem. When I shift very quickly from 1st to 2nd, it grinds the gear. Now if I shift to N quickly, then to 2nd quickly it doesnt grind. And if I shify slowly it wont grind. I always have the clutch to the floor when shifting.
I'm guessing its my syncros? It is easier to just get a whole new transmission or can the syncros be replaced for less money? I dont mind paying the money for either. I just want it done quickly.
Thanks
Old Feb 5, 2010 | 07:52 AM
you can try to replace the trans fluid with some syncromesh or redline mt-90 and see if that helps
if not
find a new trans building yours is gonna take time, im pretty sure no one stocks parts for hyundai transmissions
Old Feb 5, 2010 | 12:05 PM
Redline MT-90 will almost certainly solve your problem. I was about to replace my trans at 50k miles it was grinding so badly on the 1-2 shift, now I'm at 146k miles and it has now started grinding again, but the grind free 100k miles was nice.
Old Feb 5, 2010 | 12:33 PM
ereeves116's Avatar
Vehicle: 2002 Accent
Here'S the deal man. My Beta trans does this too. I'm pretty sure it's the synchro's like you said, but.....I don't think there's anything wrong with them. I think Hyundai's trannys just aren't built to be beaten on. I couldn't find any redline fluid locally so I just mixed in some super thick fluid with my normal tranny fluid. it kind of helped. Now that I live in the arctic, the fluid can get so thick I can't even shift until everythingn heats up, but once it does it shifts great, but sometimes it still grinds.
Swap your fluid like these guys say and you'll be happy with the result but you might still have problems. I've found that there's a TINY sweet spot where it will shift like a dream at high revs, but anything higher or lower and it'll grind. I would say shift slowly like you've been doing when you're driving normally. It's a pain but cheaper than a new tranny.
Old May 23, 2010 | 09:15 PM
Flatblack5.0's Avatar
Vehicle: 2003 hyundai accent gl
i too have this problem with mine, 76K on mine, and its only over 5500rpm that it grinds. so MT-90 redline fluid huh...
also i looked for a fill spot on the trans with no luck, found the drain but where is the fill plug at?
Old May 23, 2010 | 11:21 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
The fill plug is located up above the drain plug
Old May 24, 2010 | 09:09 PM
ill have to check again
Old May 25, 2010 | 04:45 PM
Fill plug faces directly forward on the body of the transmission about halfway up.
