Accent 3rd 4th and 5th gear ratios
I was looking around some, and found this site.
http://www.autos-korea.com/as_part/hyundai...z/spec_getz.htm The Accent shares the same transmission model, the M5AF3, as the Getz. Would it be possible to replace the 3rd, 5th, and 5th gears with those of the 1.1l Getz. and keep the current 1.6l finals to: A. reduce the chance of having to shift to 4th in the 1/4? B. Cruise at hwy speeds in 5th at slightly lower rpms.? C. Increase top speed a little? Also, are these gear ratios for the 1.6l Getz the same as for the 2001 1.6l Accent? |
Numerically higher gears are "shorter", i.e. you lose top speed and would gain some acceleration between gears. If anything you'd want longer gears as the accent tops out around 130mph.
No what you'd really need is an engine built enough to get you to 130mph. frown |
good find. can't find 01 accent gear ratios on webtech, but the 99 accent cruising gear ratio (fifth gear ratio multiplied by the final gear ratio) is 3.217, whereas the 1.1 getz fifth gear would give 2.847, a 12% drop. crude estimate says 99 accent rpm would drop by 12% on the highway.
QUOTE</div><div class='quotemain'>99mini:
good find. can't find 01 accent gear ratios on webtech, but the 99 accent cruising gear ratio (fifth gear ratio multiplied by the final gear ratio) is 3.217, whereas the 1.1 getz fifth gear would give 2.847, a 12% drop. crude estimate says 99 accent rpm would drop by 12% on the highway.Do you multiply or add gear ratios to get the final ratio? I always thought you just added the gear ratio in question to the axle ratio for the final drive in any given gear. |
If someone could, post up the gear ratio's for the 5 speed accent. I'll do up an RPM/Speed chart to compare it to the getz ratio's.
guess I will
<ul>[*]1.1 SOHC getz first gear 3.615 second gear 1.950 thirds gear 1.286 fourth gear 0.971 fifth gear 0.780 reverse gear 3.250 final gear 4.294 PUSH TYPE CLUTCH[/list] <ul>[*]US spec accent 1.6l first gear 3.615 second gear 1.950 third gear 1.370 fourth gear 1.031 fifth gear 0.825 reverse gear 3.250 final gear ratio 3.650 push type clutch[/list] <ul>[*]1.5 accent tranny first gear 3.615 second gear 1.950 third gear 1.286 fourth gear 0.971 fifth gear 0.825 reverse gear 3.250 final gear ratio 3.650 push type clutch.[/list] [ April 16, 2003, 04:16 PM: Message edited by: Shadohh ] |
sorry, I also need stock tire size for the accent, and stock tire size for the getz.
no clue. i think the accent is 14/185/75
and I think the getz is 15/185/65 |
For the LC's, 14" wheels are 185/60/14 and 13" are 175/70/13.
My X3 (97 GT) had 175/65/14's. Not sure about the 13" wheels though. |
The Getz is about half the size of an accent. I'd expect it to roll on 12's or 13's
