Accent 1.5 Engines
Old May 24, 2002 | 01:17 AM
yamaneko's Avatar
Default Accent 1.5 Engines
Other than the DOHC ones, are the 1.5L Accent Engines from 95-99 and then 00-02 the same?
Old May 24, 2002 | 11:05 AM
99mini's Avatar
i've got a 1999 brochure and a 2001 brochure. the specs on the 2 engines are exactly the same (bore, stroke, compression, hp), except that the torque is 13.2 KG.M @ 4000rpm in 1999, and 13.6 @ 4000rpm in 2001.
Old May 27, 2002 | 03:44 AM
hopper's Avatar
The engines according to my tech at dealer says they are thesame but may have done some changes to the internals. All the piece I have changed have been made for a 99 and I have a 2k. Hyundai even approved the 99 to 2k parts.
Old May 27, 2002 | 05:29 PM
According to HMA service...they use different TB's. So I'm assuming they use different IM's.
I know they also made the switch from MAF to MAP. Unknown about internal changes and exhaust changes.
Old May 28, 2002 | 12:35 AM
AfterShocK's Avatar
<div class='quotetop'>QUOTE</div><div class='quotemain'>Random:
I know they also made the switch from MAF to MAP. Unknown about internal changes and exhaust changes.</div>For the 2k+ 1.5L I believe they all used the MAF. The 2k1+ 1.6L uses the MAP
Old May 28, 2002 | 12:37 AM
<div class='quotetop'>QUOTE</div><div class='quotemain'>AfterShocK:
For the 2k+ 1.5L I believe they all used the MAF. The 2k1+ 1.6L uses the MAP</div>Doh! You are correct Sir! The 1.6L changes TB's, the 1.5L does not.
