2004 Accent fuel filter?
Old Apr 15, 2011 | 09:31 PM
turbulence's Avatar
Originally Posted by Stocker
I would have advised you to use grab a big steel mixing bowl from the kitchen and an old pot lid or 3# coffee can lid. Pull the pump assembly and drop it in the bowl, cover the ole with the lid, and do the work OUTSIDE the car with as little time as possible with wet gas exposed to the air inside. Anyway good job and I'm glad you got it sorted.
Uh, I sorta did that. I pulled the pump assembly out of the car and covered the tank opening (and tank inlet/outlet line) with a shop rag. And I did the work on a concrete surface so any drippings would quickly evaporate under the Florida sun.
