Wierd sound
Old Sep 30, 2001 | 04:13 PM
Can you identify what part of the car the sound is coming from? Back or front? Does the noise change with Engine RPM or just wheel RPM or neither?
Old Oct 1, 2001 | 03:53 PM
If you go from Reverse to N, and let the car "coast" backwards...do you still hear the sound?
If you reverse in a large parking lot, and "rev" the engine in reverse does the sound get louder/faster? If you drop it into N while going fast in reverse is the sound still there?
Old Oct 1, 2001 | 10:01 PM
Max_Kool's Avatar
I just started to hear a sound like that too last week when it started getting a bit chilly here. I thought it sounded like the rear brakes. *shrug*
Old Oct 2, 2001 | 08:06 PM
So the noise happens if the car is in N or R. And the noise gets higher pitched the faster you go.
Sounds like your brakes are dragging up front. If you let the car "roll/coast" to a stop, does the noise lower in pitch with the wheels slowing down.
Old Oct 3, 2001 | 09:04 PM
The Big Brake upgrade will not shorten your stopping distances much, as it is more to prevent brake fade, and to improve brake pedal feel.
Same with the rear Drum to Disc conversion. The rear tires do only about 20% to 30% of the braking when trying to stop quickly, due to the weight transfer to the front end. So upgrading them is really more for reduced brake fade and better pedal feel, plus some "appearance" and "bragging rights" thrown in for good measure.
The rear conversion is rather easy, the hardest part is installing/adjusting the parking brake cable.
Old Oct 3, 2001 | 10:35 PM
Jaws99's Avatar
Next time you go out to drive your car take a look at the rotors when it is cold out and or damp rust forms on them like instantly and since there is very minimal clearence between the brake and the rotor it makes a scraping sound like metal on metal until the rust is worn off. It happens with mine all the time in the cold but never in the summer so I'll bet thats your problem too.
