What type of rim is this? (Pic included)
Old May 13, 2013 | 03:41 PM
bigfishmoney's Avatar
Default What type of rim is this? (Pic included)
Are these aluminum or stainless steel? I cannot tell the difference, so it can aid in the choosing of cleaner, I cannot remove the white spots on the rims what is it?
Old May 13, 2013 | 03:59 PM
Aluminum.
Looks like they're possibly clearcoated also.
Old May 13, 2013 | 06:05 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
Sounds like someone should visit
http://www.detailersdomain.com/
Old May 13, 2013 | 11:38 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Painted aluminum. They look fairly cheap, which means the finish is probably pretty fragile.
Old May 13, 2013 | 11:52 PM
So what kind should I buy to clean they make the car go fast I want to keep for a while
the inside of the rims are painted black.
Old May 14, 2013 | 08:16 AM
i8acobra's Avatar
Any wax designed for painted surfaces... not metal polish.
Old May 15, 2013 | 07:44 PM
Do you think scrub sponges and aluminum wheel cleaner will work to clean the spots off the rim?
Old May 16, 2013 | 12:17 AM
i8acobra's Avatar
When cleaning painted wheels, the rule is simple... If you wouldn't use it on your car's bodywork, don't use it on your wheels.
Old Feb 12, 2014 | 01:39 PM
yes i8acobra i understand now
