Stuck fuel gauge
Old Mar 10, 2015 | 10:45 AM
bigfishmoney's Avatar
Default Stuck fuel gauge
Filled my tank up and the indicator, after quite a bit of driving has not moved. Also replaced the instrument cluster a few months ago.
Old Mar 10, 2015 | 07:56 PM
Has the gauge ever worked since the cluster was replaced?
Old Mar 12, 2015 | 10:43 AM
yea
Old Mar 12, 2015 | 06:47 PM
and did you change anything or do any wiring work on the car, since the last time the gauge worked?
Old Apr 2, 2015 | 01:39 PM
No I did not. It actually started going down everything is correct. The instrument cluster is working in accordance with the fuel pump component
