Hyundai Aftermarket
-   HELP Forum (https://www.hyundaiaftermarket.org/forum/help-forum-21/)
-   -   Stripping TPS Screws (https://www.hyundaiaftermarket.org/forum/help-forum-21/stripping-tps-screws-61330/)
Ben M Apr 21, 2011 01:58 PM
Hey my Tiburon needs a new Throttle Position Sensor and today i went to the junkyard to get one. There were 3 Hyundai's with the correct TPS and while attempting to remove the screws that hold it in place, I stripped them. I know that I am using the correct size screwdriver because I did get 2 screws loose on 2 different cars but then I stripped the others. My friend recommended putting a rubber band between the screw and the screwdriver but that did not seem to help. I would appreciate any help you can give me on how not to strip screws and/or how to remove the TPS without unscrewing it. Thanks!
CBowley603 Apr 21, 2011 02:04 PM
place the screwdriver where the grooves were, and hit the handle with a hammer, try to make make grooves again and also try turning the screwdriver at the same time that you hit it. Other than that, drill it out.
epinero Apr 21, 2011 02:44 PM
I used to have this problem with my civic last summer. I ended up using a dremel with a small cut off wheel to make a nice groove line on the top of the screw for a flat head screw driver. Drilling it out is always a pain...
holeshot69 Apr 21, 2011 05:45 PM
Hmm my tps has potential to be removed by a socket...any chance yours are bolts with the option of both. I was doing the same until I realized I was looking at it the wrong way.
Ben M Apr 21, 2011 06:10 PM
Thanks for the ideas guys! And I don't know about the socket removal, they looked like normal screws to me but I will check again tomorrow morning. Thanks.
Stocker Apr 21, 2011 09:26 PM
If you stripped out THREE screws you were either using the wrong tool or you don't know WTH you are doing. Let's all agree you were using the wrong tool, and take more/different tools with you the next time.
Ben M Apr 22, 2011 08:08 AM
And yes it is possible I was doing it wrong, but seeing as I got the first screw I tried out with no problem I assumed that I was doing it right but any advice would be appreciated. Thanks!
187sks Apr 22, 2011 11:13 AM
I think the best advice is to buy a better screwdriver. It makes a ton of difference even though they seem so simple. And push hard while you're trying to break it loose.
Stocker Apr 22, 2011 12:11 PM
A gunsmithing joke:
Q: What is the difference between a turnscrew and a screwdriver?
A: About $40.
krazytib Apr 23, 2011 12:17 AM
One of my TPS weak screws started doing that which was most likely caused by me over tightening them so I just replaced them both with stronger screws and problem solved. Also if it is stripped try the dremel / cutoff wheel trick as said above to make it accept a flat head screw driver or I have have also had luck using vise grips and gripping the side of the screw since the head is pretty fat to loosen it enough to so you can remove it.
The OEM screws are on the weak side and do strip easily but next time watch for this happening and stop before it's too late and try a different tool.
