Steering Vibrates around 50-80 mph
Old Oct 7, 2001 | 09:11 AM
WhoopOi's Avatar
Default Steering Vibrates around 50-80 mph
When I start off, or hit a lil bump in the road, my steering wheel will like jump... like, its very sensative.. when I start off, it feels like the tires are skipping.. and when I hit 50-80mph, the steering wheel vibrates and moves.. could there be a problem with alignment or whats the deal here?
~Drew
Old Oct 7, 2001 | 09:17 AM
Jaws99's Avatar
Either you need an alighnment or my my beat and almost 100% sure is you lost a weight off of one of you tires and need to get the wheel rebalanced.
Old Oct 7, 2001 | 10:21 AM
BigRed's Avatar
Dude u havent felt nothin, i have skinny ass tires on my 18s and when ever i punch it, the steering wheel goes nutz like its got mind of its own. I wont even go in to talking about hiting bumps or reflectors , all i got to say is hold on to ur ballz! eek.gif
Old Oct 8, 2001 | 01:20 AM
Sounds like an alighment issue, wheel weight issue, or you have warped your front brake rotors.
Your 1997 isn't under warranty any more, so I would take it to your local reputable suspension shop to have them investigate the cause.
Wheel weights should be fairly easy to figure out, you should be able to tell where one was, but the dirt/crap left when it fell off.
Old Oct 10, 2001 | 03:45 AM
FlyRideTibby's Avatar
either an alignment problem or check you tires, on my old civic, yes i said civic, i know, i broke a belt on the inside of the tire, and it would vibrate really bad between 60 and up, once the tire finally went, i replaced it and didn't have any more problems
