Random, anyone help with injectors and gurgling noise!!!!
I gotta take that back. When I removed my oil pan, there were no screens or baffles that could be knocked loose. just slosh baffles that were welded into the pan itself. I seriously doubt you knocked one of them loose!
Lemme know if the noise changes with RPM.
I forgot about the rpm's will do that tommorrow but it is more dominate on the passenger side almost sounds like it's coming from or right by the underdrive pulley but I will try the rpm's tommorrow and let you know I forgot you even told me to check that.
Jaws...seems like you are not the only one with this noise problem.
http://www.fxtreme.org/forums/cgi-bin/ulti...c&f=23&t=000087
Thanks Random atleast I know I'm not going nuts. Well I did what you said and listened while my buddy tached it up and the noise stayed the same no difference so what now? The dealership said there was no problem and it's starting to make me mad and I could be wrong but it seems like it is starting to run different in a bad way. Thanks for the help.
