Random...
Guest
Posts: n/a
Random...
Random just a thought,
Before i had the problem with the gears,i washed my engine with water(by using a hose)and threw tons of water on my motor.Do you think its possible for the water to have entered through the small hole on the top of my tranny?Could this be the problem?I mean if water is in the tranny mixed with oil maybe i have damaged it already?PLS answer me asap
I would change out your tranny fluid just in case. It is cheap and easy to do. If you can find it, use redline synthetic 70w-80 gear oil.
Www.summitracing.com carries it.
Originally posted by 2 UNIQ:
Random i heard that Synthetic Tranny oil is not that good cause it can risk you to slip gears or worse.Its not made for all trannys?
Redline in particular.I could be wrong
No synthetic gear oil is just fine. I've had no problems with my tranny or gears and I use it.
