Quick fog light help!!
Old Jan 17, 2003 | 08:09 AM
AllBlackTibby's Avatar
Default Quick fog light help!!
I got some fogs for the Wife's 01 Elantra. Which wire do I want to tap the toggle switch to so the fogs can only come on while the low beams are on?
Thanks in advance!!!
Old Jan 17, 2003 | 11:25 AM
Nevermind, I couldn't make the damn fog lights fit right.
Old Jan 18, 2003 | 05:21 AM
moving to HELP forum.
Old Jan 18, 2003 | 11:42 AM
If you use the stock fog light wiring, they will only come on with the low beams. However, they will also Not come on unless the low beams are on.
If the kit came with relays, you can also tap into the 12V positive wire going to the low beam to trigger the relay.
