No brake lights
I've checked the bulbs and wiring and everything other light "function" works, so I'm pretty sure it is the switch on the pedal. Anyone had this happen before? I'm going to look at it tonight, but if anyone has advice, mucho gracias
If even the third tail light it out, it is either a fuse (check passenger compartment AND engine compartment) or it is the switch on the pedal.
