Loud squeeking
Hey this just started happening about 2 days ago. When I start my car up, a VERY loud sqeel is coming from around the pulley area. It eventually stops after 1 minute of idling, but starts back up when being in a low gear and turning. If I turn the steering wheel all the way one direction, the loud squeel comes back and the battery light slowly comes on, but shuts off once i release the steering wheel. Any Ideas?
QUOTE (faithofadragon @ Sep 7 2010, 09:06 PM)
belt is loose
The belt on the power steering pulley appears to be tight, going to check the belt on the alternator now.
EDIT:
Just checked the altenator, is there suppost to be 2 nuts on each side of this?
QUOTE (WytchDctr @ Sep 7 2010, 09:41 PM)
You were half right. The longer bolt has threads for it, the smaller one needs a nut, at least that is how mine is setup.
Yup thats how mine is. I just tightened the threaded bolt, put a new washer + bolt on the horizontal side. No sqeeks, works nicely now.
if you ever get belt squeal, you can spray carb cleaner into the grooves. it'll stop the noise for a while temporarily. i always do it when my belts get loud.
