Hood getting stiff?
Old Jan 24, 2003 | 05:57 AM
Decker's Avatar
Default Hood getting stiff?
Here's a odd problem slowly during the last few months, my hood has been getting harder and harder to open. I mean when i pop the hood and open it, the last foot or so it travels, feels like there's resistance in it.
Any idea what causes this? Frame damgage could it be covered under warranty?
Old Jan 25, 2003 | 02:58 AM
turbulence's Avatar
i know it sounds stupid, but maybe the hinges are a little rusty? unless you've been hit, how would you have frame damage?
Old Jan 25, 2003 | 11:47 PM
Decker's Avatar
good point. I'm gonna go check it out. Mabye take the hood off and oil the hinges or something.
Old Jan 27, 2003 | 12:36 AM
You don't need to take the hood off to oil the hinges. You can do it with the hood on.
Just make sure your hood is not rubbing the fenders at the corners up by the windshield. If your hood gets out of line, a gap will open up on one side, and it will rub/scrape the fender on the other side.
Old Jan 27, 2003 | 12:40 AM
Decker's Avatar
well they're not rubbing the fenders, but i did notice that there are gaps right above both headlights. The center part hooks and seals good, but the sides have about 2-3mm gap between the hood and the rubber. But apart from that the gab between the fenders and hood are consistent.
Do you think that mabye my strut bar is tightened to mutch and mabye pulling the body together too mutch?
