elantra 2002 overheating
Old Jun 25, 2011 | 01:45 PM
hbtdawgs's Avatar
Vehicle: elantra
Default elantra 2002 overheating
hi my elantra is running hot water is rusty so i flushed it out still running hot heater working when it sits and idles temp is normal but when u drive it over heats any ideas?
Old Jun 25, 2011 | 04:11 PM
The coolant should not be plain water, because it will rust. It should also not be rusty. A thermostat that does not open all the way could cause overheating while driving. Pull the thermostat and check it. Or heck, they're cheap and if it's the original your thermostat is old, just get a new one and see if that was it.
If the coolant is actually oily instead of rusty (looks like coffee) then you may have a blown head gasket.
Moved to the appropriate section.
Old Jun 25, 2011 | 07:34 PM
hbtdawgs's Avatar
Vehicle: elantra
CHANGED the thermostat and that did it thanks for the help.
Old Jun 25, 2011 | 08:53 PM
Hey I'm happy you got it going. Do keep an eye on that coolant color.
If you are responding to the last post in a thread, please use the Add Reply or Fast Reply buttons instead of quoting the entire previous post.
Old Jun 25, 2011 | 08:55 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
Glad to hear it was something simple and cheap!
BTW - Why do you guys not like us quoting posts? Just wondering....
Old Jun 25, 2011 | 09:24 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
It is sort of weird if the very next post is quoting the post above it. It only annoys me when people quote a long string of pictures... I JUST SAW THEM?!@?!?@!?@!!!@?!?@!@
Old Jun 26, 2011 | 02:36 PM
hbtdawgs's Avatar
Vehicle: elantra
well this morning i found a leak around thermostat housing tried to tighten the cover an heard a crack any ideas where i can get the housing with out going to dealer?
Old Jun 26, 2011 | 05:25 PM
pas1216's Avatar
junkyard, just call around to a few of your local yards. I'm sure they would have one and it shouldn't be any more than $20 bucks
Old Jun 26, 2011 | 08:39 PM
+1 to be a long term owner of a decade-plus old car, get to know the local junkyards.
