ECU
Vehicle: 1997 hyundai coupe
I have a tiburon RD1 and the ECU is no good, and i wonder what i'll need to do to replace it.
i gather i will need a
ECU
ignition barrel
door locks
key
is there anything else i need to do? i.e get it reprogrammed or is it a straight swap
Thanks
ECU
ignition barrel
door locks
key
Thanks
To replace the ECM you replace . . . the ECM. Unless you're in a country where they did something strange with an immobilizer (please fill out your member profile so we know where you are) in which case you may need to make a trip to a dealer or be out of luck. For USA-spec RDs, just the computer. The door locks are just solenoids and the ignition switch is just a switch.
