Cylinder no.2 misfire CEL
Old Jan 28, 2015 | 07:29 PM
bigfishmoney's Avatar
Default Cylinder no.2 misfire CEL
I have a 2001 Hyundai Tiburon w/ 130,000 miles on engine that's throwing a CEL cylinder number 2 misfire
I have replaced #2 fuel injector, ignition coil, and checked the spark plugs
after resetting the ECU the CEL comes on again after an hour or so of relentless driving
examples:
when depressing gas pedal when going up slight inclines I can trigger the cel by giving it a lot of gas and it gives up and goes into limp mode again
or on the highway constantly at 65 MPH now it starts to sputter out the exhaust ( a spitting sound ) and the CEL comes on again putting it into limp mode an d it runs fine like that.
What could this be?
Thanks
Old Jan 28, 2015 | 07:56 PM
I also replaced the timing belt a 1,000 miles ago
Old Jan 28, 2015 | 10:25 PM
Last misfire episode I had was a bad spark plug wire.
Old Jan 29, 2015 | 12:46 PM
onecrazyfoo4u's Avatar
Have you moved the spark plugs and plug wire to a different location to see if it follows to the next cylinder? That would be the easiest check first.
Old Jan 29, 2015 | 07:31 PM
The wires are location-specific, can't swap em around without a second set. Usually my car is reliable for long enough that when wires are suspected they are also old, and I just change them out with new.
Old Apr 2, 2015 | 01:37 PM
I replaced the spark plug wires and now there is no misfire.
Old Apr 2, 2015 | 09:26 PM
I LOVE when that happens.
Old Jul 10, 2015 | 08:42 AM
misfire has returned could oxygen sensor cause this? I suspect a burnt valve, car emitting black smoke as well sometimes. Picking up a low mileage cylinder head from a local junkyard
Old Jul 10, 2015 | 09:35 PM
if you are getting black smoke, it's gas and your tuning is off. A bad oxygen sensor might cause that. Get a code reader on it, and see what it says. Better yet, step up your coder reader to mid-grade, and see what the O2 sensor is saying in real time and check out your fuel trims.
