Cruise control not working
My cruise control button lilluminates, but the green 'Cruise' word does not appear on my instrument cluster while pressing the cruise control button on the end of the multi function switch on the steering column. So cruise control does not engage entirely at all on the highways.
It does not appear that there are any mechanical problems though. Like, anything out of place.
Where might I find the relay location for this type of problem in the cabin?
Check your driver side brake light. If it's burnt out or if you have led with no load resistor, the cruise control will not function.
mechanically it used to work, i dont think it snapped or anything, i was in a minor fender bender and a lot of small electrical components malfunctioned on the instrument panel due to the impact(gas indicator light not working or blinking off and on, turning signal switch ticking like a bombs about to go off, and dosen't stop sometimes). which leads me to believe this is just another thing that needs looked at too..
anyone know where the relay is @??
