burnt bulb
Old Nov 9, 2001 | 02:43 AM
Y2KTIBLTD's Avatar
REAR COMBINATION LAMP
1.) Disconnect the negative terminal from the battery.
2.) Open the trunk lid.
3.) With rear luggage cover opened, remove the mounting nuts.
4.) Disconnect the connector, remove the lamp assembly.
5.) Installation is the reverse order of removal procedure.
Hope this helps!
Old Nov 10, 2001 | 08:09 AM
Tuscani Elisa V6's Avatar
why disconnect battery ans lose your favorite stations?
no need to disconnect battery in order to change a bulb
Old Nov 10, 2001 | 09:28 PM
simp's Avatar
Even worse. sad.gif I'd had to retune the equalizer of my Kenwood. Damn thing reset itself to factory default.
