brake pedal to floor!!!
after swapping out the rear pads and readjusting the calipers....my brake pedal goes to the floor....i added brake fluid and it still goes to floor!!! what the hell did i do?? i pump on the pedal i feel pressure and then 2 secs lateri have no more pressure!! help!!
You, my friend, have to bleed your brakes. You have air in them. I'm guessing, by you not having much knowledge of brake systems, should have your brakes bled by a professional. i'm not being mean, it's just that, yeah, it's not a good idea to be playing with brakes when you don't know what you're doing.
Sounds like ya broke something.
mmmm, dont know to much about how diagnose braking problems. But is it spongy when ya press down on it? Hyundais dont need to be rebled after new brake pads. But... Maybe yours is funky? |
what could i of possibly have broken??? i dont know....changing the pads is a simple deal....but i obviously missed something....
from hma...
http://www.hmaservice.com/webtech/ii...d=12426#_12426 it looks like you should try bleeding them first. hmm, didn't work... here's the link http://www.hmaservice.com/webtech/iindex.a...id=12426#_12426 [ March 03, 2003, 08:46 AM: Message edited by: turbulence ] |
Hang on here... changing brake pads usually doesn't require you to open up the hydraulic system, so unless you DID disconnect a brake line or something, the system shouldn't need bleeding.
Maybe you misadjusted the calipers? That's just a guess, assuming you didn't disconnect any brake lines. Are you losing brake fluid? Check for leaks, perhaps. Or could a caliper be sticking? Tough call without knowing all the details of the work you did or without being able to look at the car too... Keep up posted. |
It sounds like you got air into the system somehow. Normally, this does not happen if you are just replacing pads.
The other option would be a leak/hole in the brake line, but I think you would notice the puddle of brake fluid under the car if that was the case. Just wondering, when you compressed the rear brake caliper pistions to fit the new pads on, did you take the cap off the brake fluid resivior? If not, you may have blown the master Cylinder. Bleed out your brake system starting at the passenger rear, then drivers rear, then passenger front, then drivers front. Make sure you keep adding new fluid to the resivoir...never allow it to run below the "minimum" mark. If that doesn't solve it, you've got a blown master cylinder. |
yeah, that's what i meant. i realize that you don't open the brake lines when you change the pads, but it really sounds like there is air in there. there's a possibility the calipers aren't adjusted correctly. i would get a buddy and bleed the system.
