Polished Shifter Ring Group Buy *$60 Shipped*
Old Nov 6, 2007 | 04:55 PM
frozen's Avatar
Vehicle: 2001 Tiburon
I'm in for sure, and would actually prefer to pay in advance. What is the ETA on these things after everyone is paid up?
Old Nov 6, 2007 | 05:57 PM
BLK2KTIB's Avatar
I'm in.
Whats involved for installation?
Old Nov 6, 2007 | 06:30 PM
JonGTR's Avatar
^^^Extremely easy. Remove the shifter surround. Unscrew the 4 screws holding the stock ring in. Replace with new ring using new bolts and nuts. Also, you would need to drill holes in the plastic where the other 4 bolts will go. It doesn't need to look pretty cause it will get covered.
Old Nov 6, 2007 | 07:11 PM
Mr. Muffin's Avatar
Vehicle: 01/hyundai/tiburon
<div class='quotetop'>QUOTE (Tibbychick @ Nov 6 2007, 07:10 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I'm not stupid REDZ, I drive my car everyday. Please don't patronize me. I know you like to pick people apart but there's really no need to do it in this situation. I was simply hoping that maybe one could be made for the RD1, like the F2 one that Xorro had on her car (http://www.hyundaicoupe.info/pix/mine/mine282.gif). But yeah, I'll keep my mouth shut from now on so as to not clutter the thread.</div>
and i was about to say somthing about how he took it easy on u cause ur a chick... laugh.gif
is the rd2 surround a direct swap into an rd1, just pop it in?
ill probably be in on this to, i dn if i should get this or gauges first
Old Nov 6, 2007 | 08:03 PM
javageek's Avatar
I want in on this too, but will not be able to do anything until the end of the month.
As for the RD1-RD2 conversion, I think you have to swap the whole dash out otherwise it will not match up to the shift surround.
Old Nov 6, 2007 | 08:07 PM
I think youre right Java. Ill try to put my rd2 shift surround on the rd1 if i think of it and just check
Old Nov 6, 2007 | 08:54 PM
<div class='quotetop'>QUOTE (JonGTR @ Nov 6 2007, 06:30 PM) <{POST_SNAPBACK}></div><div class='quotemain'>^^^Extremely easy. Remove the shifter surround. Unscrew the 4 screws holding the stock ring in. Replace with new ring using new bolts and nuts. Also, you would need to drill holes in the plastic where the other 4 bolts will go. It doesn't need to look pretty cause it will get covered.</div>
Actually, according to LARRS, if you did the 8 bolts, 7 of the holes will line up and you'll only have to drill one through.
And yes, if you use the RD2 Shifter surround on a RD1, it'll WORK, but it won't match up perfectly because of some curves where the stereo surround hits the shifter surround. Sand it and paint it, swap the dash, what have you.
Old Nov 7, 2007 | 06:17 AM
JonGTR's Avatar
I'm sure the payments will drag out til the end of the month. As long as you're sure you'll have the payment, I'll put your name on the list.
Old Nov 7, 2007 | 12:59 PM
You should PM folks from the other threads that were interested about it.
Or take out a signature loan. LOL
Old Nov 7, 2007 | 01:33 PM
why not hit up hp?
