*First US release*
The newly released X-TRM Super Single Clutch Kit uses the latest clutch technology to create a super lightweight clutch system that dissapates heat quickly and holds all the power your BETA engine can produce. These clutch systems are rated to hold 400+WHP and have been engineered to provide long-lasting performance. The forged flywheel is one of the lightest in its class ( 3.6KG ~7.9lbs) couple with the 5 puck clutch disc and billet aluminum pressure plate make it one of the lightest clutch system available for our vehicles. The pedal pressure is only slightly harder than stock and the clutch system is VERY streetable... even during rush hour. Those of you with VHR systems already, it feels even better - I've had both in my car. For the first release of the X-TRM Super Single Clutch kit, I've been given pricing that's better than on the Korean economy. Koreans have to pay over $1000 USD PLUS shipping: Babomall Price Pricing will be $750 USD shipped until further notice!!! I'll be running this on other forums as well, so we should only have to come up with about 5 to hit the top tier. https://i43.photobucket.com/albums/e...irun/xtrm1.jpg [attachment=213:attachment] |
what are the differences between this kit and the VHR kit with the 4 puc sprung disc ??
can i just buy the clutch disc ? |
You could, but it would do you no good. It's the combination between the pressure plate and the clutch disc that hold down the power. Main differences: Lighter rotational mass 100+whp higher capacity Higher heat dissapation (critical) Longer clutch life Easier clutch engagement Here's a PDF that breaks the clutch system down and lets you know of all the benefits and construction |
that might be a bit too much for the site to handle, but ill let supercow(tech) know about this.
is there a no flywheel option or is it pretty much a package deal?
It's a package deal since the flywheel is customized to the pressure plate and the mountings are different from stock.
Supercow-
The box that let's me browse and attach is missing... It's missing between Post options and post icons |
It won't let me add your attachment either mang. It's not showing up at all. |
hum... try it again.
edit: it shalt worketh saith the supercow!!!! lmao.gif airborne, just try it again from your end to make sure and i'll just delete my attachment. |
